Старый 03.05.2012, 12:11   #1
workflowax: What happened to the Workflow History Form in AX 2012?
Источник: http://workflowax.wordpress.com/2012...rm-in-ax-2012/
If you’ve stated to use workflow in AX2012 you’ve probably noticed that the workflow history from is no longer where it used to be. Previously in AX2009 it was available under Basic -> Enquires -> Workflow History.
You can now find the workflow History Form in AX 2012 under Home -> Enquiries -> Workflow -> Workflow History.
workflowax: Workflow Session at Dynamics AX 2012 Technical Conference Blog bot DAX Blogs 0 08.02.2011 18:11
Ошибка бизнес-процесса Tarasov E Dynamics CRM: Разработка 9 18.02.2010 14:02
Часовой пояс GMT +3, время: 07:21.
