Старый 27.06.2008, 11:05   #1
axaptapedia: Filter-by-Grid
Источник: http://www.axaptapedia.com/Filter-by-Grid
Summary:
The filter-by-grid feature is a commonly-used way of filtering records in a grid.
== Turning on the filter-by-grid ==
* Click inside the grid (set focus on the grid). Press '''ctrl + g'''. You can press '''ctrl + up''' to move the cursor from the rows into the filter area.
* Click the filter-by-grid button in the tool bar.
== Turning on filter-by-grid by default on a specific form ==
Call the task method on the form element with the number 2855. You should place the following code in the '''run''' method.
void run()
super();
this.task(2855);
== Turning on filter-by-grid by default on all forms ==
Place the following code inside of SysSetupFormRun.run().
this.task(2855);
== Quirk ==
Any form that has the grid as the first input control will show the filter-by-grid and others will not. There are two workarounds: set all controls before the grid to Skip = Yes or override the '''firstField''' method on the form so that the grid is selected first. The overriden firstField method should set focus on the grid. It will not enable the filter-by-grid feature on all grids on the form.
void firstField(int flags=1)
overviewGrid.setFocus();
[[Category:Form development]]
Старый 30.05.2012, 12:58   #2
AndyPanda is offline
AndyPanda
? ололо
А что делает-то этот task? и почему именно 2855?
А по сути, мне нужно реализовать фильтр по полю на гриде.
Старый 30.05.2012, 13:39   #3
S.Kuskov is offline
S.Kuskov
3,449 / 1792 (66) ++++++++
Сообщение от AndyPanda Посмотреть сообщение
То же, что и сочетание клавиш 'ctrl + g'
Что б никто не догадался
Для этого работайте не с контролами формы, а с query источника данных. Метод AddRange объекта Query поможет вам добавить "фильтр по полю".
hariprasadp: Grid Filter while open a form in Dynamics AX Blog bot DAX Blogs 0 07.05.2008 15:05
Kashperuk Ivan: Hotkeys and Find vs Filter in Dynamics AX 2009 Blog bot DAX Blogs 2 11.03.2008 12:06
axaptafreak: Automatically open grid filter when opening form Blog bot DAX Blogs 2 20.06.2007 18:36
Dynamics AX: DAX 4.0 Filter by Grid [Update] Blog bot DAX Blogs 0 27.04.2007 17:10
Advanced programming: Grid data and view manipulations batiskaf_new DAX: Программирование 15 21.06.2006 11:44
Часовой пояс GMT +3, время: 05:49.
