#1 |
ax-erp: Ax2012 Validate XML and Show XML in form
Источник: http://microsoft-dynamics-ax-erp.blo...l-in-form.html
============== The following sample job used to show any xml,XSLT,XSD schema in the form and validate that XML. In this example I have the table with the xml value stored in it. if you want to validate from file also we can do as well. static void Krishh_LoadXmlform(Args _args) { ChangeOrderSourceLog sourceLog; AifXmlViewer viewer; ; select firstOnly from sourceLog where sourceLog.changeOrdernum='3369'; if(sourceLog ) { // construct the AIFXMLViewer class object by the xml value and the type of the XMLFile. viewer=AifXmlViewer::construct(sourceLog.ChangeOrderSourceXML,AifXmlType::XML); viewer.show(); } } Источник: http://microsoft-dynamics-ax-erp.blo...l-in-form.html
