Старый 09.01.2013, 01:11   #1
sashanazarov: Marking from code: part 2
Источник: http://sashanazarov.blogspot.com/201...de-part-2.html
In this post, I provided a code sample that manipulated InventMarking form from code to complete an ad-hoc task.
Today I had to implement marking from X++ code again, but this time it should have been run on the server side on a daily basis, so I did have to use
\Data Dictionary\Tables\TmpInventTransMark\Methods\updateTmpMark
method instead of the form.
As code samples I found in the Internet were outdated, I decided to post here code that did compile on my box (DAX 2012 CU3):
static void testXppMarking(Args _args)
InventTrans issueInventTrans;
TmpInventTransMark tmpInventTransMask;
Map mapMarkNow;
container con;
real qty;
Map mapTmp;
MapEnumerator mapEnumerator;
InventTransOriginId issueInventTransOriginId =
InventTransOrigin::findByInventTransId('Issue lot ID').RecId;
InventTransOriginId receiptInventTransOriginId =
InventTransOrigin::findByInventTransId('Receipt lot ID').RecId;
InventQty qtyToMark = 11;
ttsBegin;
issueInventTrans = InventTrans::findByInventTransOrigin(
issueInventTransOriginId);
[con, qty] = TmpInventTransMark::packTmpMark(
InventTransOrigin::find(issueInventTransOriginId),
issueInventTrans.inventDim(),
issueInventTrans.Qty);
mapTmp = Map::create(con);
mapEnumerator = mapTmp.getEnumerator();
while (mapEnumerator.moveNext())
tmpInventTransMask = mapEnumerator.currentValue();
if (tmpInventTransMask.InventTransOrigin == receiptInventTransOriginId)
tmpInventTransMask.QtyMarkNow = qtyToMark;
tmpInventTransMask.QtyRemain -= tmpInventTransMask.QtyMarkNow;
mapMarkNow = new Map(Types::Int64, Types::Record);
mapMarkNow.insert(tmpInventTransMask.RecId, tmpInventTransMask);
TmpInventTransMark::updateTmpMark(
issueInventTransOriginId,
-qtyToMark,
mapMarkNow.pack());
break;
ttsCommit;
За это сообщение автора поблагодарили: Pandasama (1).
sashanazarov: Manipulating the Marking form from code Blog bot DAX Blogs 6 17.10.2012 15:29
furnemont: How-to series: Send SMS messages from CRM 2011 (part 3) Blog bot Dynamics CRM: Blogs 0 13.06.2011 12:11
CRM DE LA CREME! Some more useful javascripts for MS CRM Blog bot Dynamics CRM: Blogs 0 04.05.2010 11:05
Microsoft Dynamics CRM Team Blog: List Web Part for Microsoft Dynamics CRM 4.0: Understanding Connections Blog bot Dynamics CRM: Blogs 0 20.01.2009 02:07
Часовой пояс GMT +3, время: 05:41.
