#1 |
dynamicscare: Using Excel to Update Demand Forecasts in Dynamics AX 2012
Источник: http://dynamicscare.com/blog/using-e...amics-ax-2012/
============== Dynamics AX has an add-on for Microsoft Excel that allows you to retrieve data from Dynamics AX, and also publish changes back to the database in a controlled way. You can use this to give users a simpler way to manipulate the information in the database. As an example, you can use this to create [...] Источник: http://dynamicscare.com/blog/using-e...amics-ax-2012/
