Старый 27.04.2013, 01:16   #1
axnontechnical: Lanch Report Designer from within the Dynamics AX 2012 R2 client
Источник: https://community.dynamics.com/ax/b/...r2-client.aspx
(Please visit the site to view this video) Learn how to Make Management Reporter accessible from within Dynamics Dynamics AX 2012 R2. See our blog at http://blogs.msdn.com/b/dynamicscpm for more information....(read more)
Старый 27.04.2013, 01:16   #2
dynamicscpm: Launch Report Designer from within Dynamics AX 2012 R2 Client - Management Reporter RU5
Источник: http://blogs.msdn.com/b/dynamicscpm/...orter-ru5.aspx
Using Management Reporter with Dynamics AX is easier than ever now that you can launch Management Reporter Report Designer from the menus in both Dynamics AX General Ledger and Budgeting. Only users that have permission to design or generate reports in Management Reporter will have the menu item available.
This video shows how you'll be able to launch Management Reporter from within Dynamics AX 2012
How do I get this new Dynamics AX functionality?
Use the following steps to load the Dynamics AX hotfix that adds the menu items:
  • If you are on Dynamics AX 2012 R2, follow the steps in KB 2840107 in order to download the prerequisite update to Dynamics AX.
  • Apply the update to Dynamics AX.
The hotfix will be included in Cumulative Update 6 for Dynamics AX 2012 R2 as well.
After the hotfix has been installed, you will have menu items available but they are not yet configured to launch Management Reporter yet.
Do I need to do anything in Management Reporter?
  • Management Reporter needs to be updated to Rollup 5 (2.1.1037.12) or later.
  • To finish setting up the Dynamics AX menu items, you will need to use the Management Reporter Configuration Console to publish the location of the MR server into Dynamics AX using the "publish server connection" action. Once this has been done, the Management Reporter server address and the default company will be supplied by Dynamics AX.
  • The Management Reporter client will need to be installed where the Dynamics AX client is installed. This can either be on local machines or on one or more Terminal Servers.
How do I remove the existing Dynamics AX financial statement forms?
The ability to disable existing AX Financial Statement functionality and hide those menu items is done by via a license configuration key. If you are using Management Reporter you can disable this key to hide the existing X++ based financial statements.
  1. Click into System within Dynamics AX
  2. Under the Setup Area click on Licensing
  3. Click on License Configuration
  4. Uncheck the option for Financial statement (traditional)
  5. Click OK
Старый 27.04.2013, 01:16   #3
msdyncomm: Lanch Report Designer from within the Dynamics AX 2012 R2 client
Источник: http://www.youtube.com/watch?v=xjb5j...=youtube_gdata
0 ratings
Time: 01:11 More in Science & Technology
axnontechnical: Management Reporter and Microsoft Dynamics AX 2012 R2 Budget Planning Blog bot DAX Blogs 0 16.02.2013 08:08
dynamicscpm: Management Reporter is now available on the Dynamics AX 2012 R2 Demo VM Blog bot DAX Blogs 0 19.01.2013 08:12
dynamicsaxbi: Better together: Microsoft Dynamics AX 2012 R2 and SQL Server Power View Blog bot DAX Blogs 0 12.12.2012 13:11
rumicrosofterp: Dynamics AX на Convergence 2012 Blog bot Microsoft и системы Microsoft Dynamics 0 13.01.2012 11:11
dynamics-ax: Product Management with Microsoft Dynamics AX 2012 - Part IV Blog bot DAX Blogs 0 01.06.2011 04:14
Часовой пояс GMT +3, время: 00:39.
