Старый 28.05.2013, 15:11   #1
dynamicsaxbi: Best Practices: Coding Guidelines
Источник: http://blogs.msdn.com/b/dynamicsaxbi...uidelines.aspx
Microsoft Dynamics AX 2012
Developer’s checklist when creating report solutions for Microsoft Dynamics AX 2012.  The goal of this article is to promote coding guidelines that have been applied by the product development team to ensure consistency in the reporting solutions across the application.  Many of the suggestions here stem from the hundreds of developer hours invested when migrating >1000 legacy production reports into Microsoft Dynamics AX 2012.  Applying these strategies will help to ensure that your reports are robust and scale appropriately when deployed to production environments.
DO USE…. identifierStr to specify identifiers like parameter names
As explained in the MSDN article here, the identifierStr() method is used to convert an identifier into a string.  Even though the article says that this method validates its argument in the AOT, the only check it seems to make is that its argument would be a valid identifier.  The main benefit of using this method is that we don’t need to put the string in quotes like ‘BookId’; instead we can simply use identifierStr(BookId).
This method is mainly used in the contract class, for the parm methods.  For example, the parm method can be decorated with the DataMemberAttribute attribute which specifies the parameter name.
This can be specified using the identifierStr() method as follows:
<ul> <font size="3">DataMemberAttribute(identifierStr(DocumentDate))
dynamicsaxbi: Best Practices: Report Data Methods Blog bot DAX Blogs 0 28.05.2013 15:11
dynamicsaxbi: Best Practices: Introduction Blog bot DAX Blogs 0 28.05.2013 08:11
Dave Froslie: Dynamics AX 2012 Testing Best Practices Now Available!! Blog bot DAX Blogs 0 07.10.2011 21:11
kamalblogs: Towards Dynamics Ax Product Certification – Best Practices (Part III) Blog bot DAX Blogs 0 21.07.2010 01:07
Microsoft Dynamics CRM Team Blog: Best Practices for CRM Memory Usage Blog bot Dynamics CRM: Blogs 0 12.03.2009 23:05
Часовой пояс GMT +3, время: 12:35.
