Старый 19.08.2013, 19:11   #1
dynamicscpm: How to import default building blocks -- Management Reporter CU6
Источник: http://blogs.msdn.com/b/dynamicscpm/...orter-cu6.aspx
Existing customers with reports already created in Management Reporter can also take advantage of the default reports included with Management Reporter CU6.
From the Tools menu in Management Reporter, just select Import Default Reports. You'll be able to choose the reports you'd like to import. If you'd like all of them, choose Select All, otherwise pick the specific reports you want and click Import.
dynamicscpm: Using default row definitions -- Management Reporter CU6 Blog bot DAX Blogs 0 17.08.2013 00:17
dynamicscpm: Using default column definitions -- Management Reporter CU6 Blog bot DAX Blogs 0 16.08.2013 03:24
dynamicscpm: Migrating to Management Reporter 2012 Blog bot DAX Blogs 0 24.05.2012 01:13
dynamicscpm: How can you get Management Reporter 2012? Blog bot DAX Blogs 0 11.04.2012 18:11
Часовой пояс GMT +3, время: 20:34.
