Старый 29.08.2013, 02:11   #1
dynamicscare: Getting Started with Dynamics AX 2012: Using Templates for Item Setup
Источник: http://dynamicscare.com/blog/getting...or-item-setup/
Correct item setup is key to a company’s ability to successfully utilize its ERP. But, if you have ever been tasked with item entry, you understand how tedious and daunting a task it can be. In Dynamics AX 2012, you have the ability to create item templates which can significantly improve the timeliness and accuracy [...]
dynamicscare: Getting Started with Dynamics AX 2012: And 1 And 2 And 3….. Blog bot DAX Blogs 0 23.08.2013 09:11
dynamicscare: Getting Started with Dynamics AX 2012: Intercompany Accounting Blog bot DAX Blogs 0 16.08.2013 03:24
DAX: How to gain additional value from the Microsoft application platform with Microsoft Dynamics AX 2012 R2 Blog bot DAX Blogs 3 21.06.2013 15:16
Dynamics AX Sustained Engineering: Servicing of Dynamics AX 2012 and Dynamics AX 2012 Feature Pack Blog bot DAX Blogs 0 08.05.2012 23:12
Часовой пояс GMT +3, время: 09:32.
