Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 15.12.2013, 20:42   #1
ist is offline
ist
AIF web services and ASP.NET MVC web application
Hi,
I have very strange problem with AIF. I have ASP.NET MVC application which consumes AIF WCF web services. My Scenario is: AX 2009 SP1 RU8 running on Windows Server 2012. On that machine I have one AOS which is load balancer. I have another 4 AOS's. Every one of them runs on a different virtual machine, so I have 5 AOS'es over 5 different machines with Windows Server 2012 operation system. ASP.NET MVC application and AIF web services applicatoion pools are running with busines connector account. BC configuration points to the AOS which is load balancer. One of ASP.net MVC application forms (especialy login form) has a problem when the AX client is started. When I stop AX there is no problem. When AX works with one AOS (without load balancer) everithing is OK. The problem is:
Message: <Fault xmlns="http://schemas.microsoft.com/dynamics/2008/01/documents/Fault">
<Code />
<Reason>
<Text xml:lang="EN-US">Request Failed. See the Exception Log for details.</Text>
</Reason>
</Fault>Stack trace: at Microsoft.Dynamics.BusinessConnectorNet.Axapta.CallStaticClassMethod(String className, String methodName, Object[] paramList)
at Microsoft.Dynamics.IntegrationFramework.Service.WcfAxAdapter.SubmitMessageToAx()
I have no idea what's the problem.
Thanks,
aif
daxdilip: Fiddler - Good tool to check EP web page, custom websites, performance and AIF Web services Blog bot DAX Blogs 0 04.12.2010 14:11
axaptasource: Fiddler – Good tool to check EP web page, custom websites, performance and AIF Web services Blog bot DAX Blogs 0 04.12.2010 14:11
emeadaxsupport: What changes are required if we change the Business Connector Proxy used by AX 2009 Generated AIF Web services Blog bot DAX Blogs 0 29.03.2010 15:05
Arijit Basu: Infopath, Web Services & AX Integration Blog bot DAX Blogs 0 04.05.2008 23:05
Inside Dynamics AX 4.0: The Web Framework Blog bot DAX Blogs 0 25.10.2007 03:04
Часовой пояс GMT +3, время: 07:17.
