Старый 12.06.2014, 02:12   #1
david_kidder: How to Test a SQL Connection from any Windows Machine
Источник: http://blogs.msdn.com/b/david_kidder...s-machine.aspx
Here are some quick steps you can take to test a SQL Connection from any Windows machine:
Hit Windows Key + D to show the desktop.
Right-click on the desktop and choose to create a new text document
Rename the file to something that ends with the file extension UDL (this is the important part)
After which, it should look like this:
Double-click the file, which should open this window:
There you go, you have this window which should be familiar.  Enter the Server name, choose NT Integrated security if your server is using Windows logins or fill in the user name and password if it’s using SQL auth and optionally select a database then hit Test Connection at the bottom.
За это сообщение автора поблагодарили: trud (1), gl00mie (5).
david_kidder: AX Window Management Tips Blog bot DAX Blogs 0 05.09.2013 15:11
Axilicious:Running AX2012 R2 locally on Windows 2012 Server booted directly from VHD Blog bot DAX Blogs 0 16.04.2013 08:13
ax-erp: How to pass value from MenuItemButton to a Dialog Class? Blog bot DAX Blogs 0 19.09.2012 20:11
daxdilip: Tip - How to avoid Overriding of SQL Indexes from AX when a Full Synchronization is done Blog bot DAX Blogs 0 12.05.2011 08:11
Часовой пояс GMT +3, время: 14:53.
