Старый 19.06.2014, 18:11   #1
atinkerersnotebook: Start The Workflow Processor From The Tools Menu
Источник: http://atinkerersnotebook.com/2014/0...he-tools-menu/
Originally posted on Dynamics AX Tip Of The Day:
If you have done any development and testing with workflows in Dynamics AX, then you are probably all too familiar with the on-demand Workflow Processor application that you can run at your leisure in order to see all of your workflows in action. It is great for testing because you don’t have to have a batch process running in the background. The only problem is that since it’s more of a development tool, accessing it requires you to search for it within the backwaters of the AOT every time that you want to run it. Thankfully with the R3 release, it has been promoted to the Tools menu, and is now just a few clicks away from you at any time.
It’s like when Starbuck saved Cy and they ended up working together to survive…
View original 42 more words
atinkerersnotebook: Using Vendor Requests to Manage On-boarding New Vendors Blog bot DAX Blogs 1 22.10.2013 02:24
atinkerersnotebook: Using PowerPivot to Analyze Dynamics AX Data Blog bot DAX Blogs 1 05.10.2013 07:23
atinkerersnotebook: Configuring Lean Manufacturing in Dynamics AX 2012 Blog bot DAX Blogs 1 12.08.2013 00:15
Ошибка бизнес-процесса Tarasov E Dynamics CRM: Разработка 9 18.02.2010 14:02
Часовой пояс GMT +3, время: 18:49.
