Старый 30.06.2014, 13:11   #1
bojensen: Accessing datasource field properties – Axaptapedia
Источник: http://blogs.bojensen.eu/?p=4891
Often it is useful to be able to access the datasource field properties on a form through X++. This is essential for modifying the allowEdit property at run-time for example. The following code can be used to set the allowEdit of the InventTable.ItemName field on a form. FormDataObject fldItemName; boolean allowEdit = false; //This would…
Read more →
Старый 13.07.2014, 01:58   #2
kashperuk is offline
kashperuk
Аватар для kashperuk
4,361 / 2084 (78) +++++++++
Бред какой-то
emeadaxsupport: Fill Utility incorrectly updates a field that is not in the field list of the main datasource Blog bot DAX Blogs 0 27.01.2012 01:12
Kashperuk Ivan: Tutorial: AX 2012 - Invalid field access or Accessing unretrieved fields Blog bot DAX Blogs 0 29.10.2011 05:18
axaptapedia: Table Field Group Blog bot DAX Blogs 0 02.07.2011 05:37
axaptapedia: Table Field Group Blog bot DAX Blogs 0 25.06.2011 06:33
Часовой пояс GMT +3, время: 01:47.
