#1 |
emeadaxsupport: Belgian EUSalesList xml file missing the sending company's contact information
Источник: http://blogs.msdn.com/b/axsupport/ar...formation.aspx
============== If you viewing XML file created by AX to report the EU Sales to Belgian authorities and experience that the XML file doesn’t include the company's contact information such as the user's email and Phone number in the xml file header. This information is mandatory on the INTERVAT website and without this information the XML file generated file will be rejected. We have released KB3003995 “Company electronic address is not marked as IsPrimary for the location when creating a new company”. But if the “New” legal entity have been created before the KB or the KB isn’t installed you may check and update this manually. This issue happens because while generting EUsalesReporting, system uses the AXDEUSLReporting query. In query for dirpartylocation datasource and to this datasource, records are filtered based on condition Isprimary. But for new created Legal entities and while creating electronic address for these new legal entity- Isprimary is never marked as true, so because of ElectronicAddress not being marked as primary in DirpartyLocation, so Dirpartylocation record related to electronic Address is not being fetched and hence Contact Information is not reflecting on the EUSalesListreport. And please remember to re-load the EU Sales list XSLT document after HF update. If the company is already created and in use you may need to fix this manually…. Please validate the status of the tick box IsPrimary in the DirPartyLocation table? Which address RECID can be found in LogisticsElectronicAddress. If you have this issue would expect that in that case this box in DirPartyLocation table will be blank so as a work around I suggest to mark it and save and rerun the EU Sales list and the info will be there. ![]() ![]() ![]() - Источник: http://blogs.msdn.com/b/axsupport/ar...formation.aspx
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
