Старый 13.12.2015, 09:12   #1
mfp: X++ in AX7: Internal keyword
Источник: http://blogs.msdn.com/b/mfp/archive/...-internal.aspx
internal is a new keyword in X++. It has the same semantics as in C#.
When you mark a class or method as internal, then it can only be accessed from within the model where it is defined.
internal class MyInternalClass
internal void myInternalMethod()
Notice, you can define internal methods on public classes too.
THIS POST APPLIES TO MICROSOFT DYNAMICS AX7 TECHICAL PREVIEW; IS PROVIDED AS-IS AND CONFERS NO RIGHTS.
mfp: X++ in AX7: Client/Server keywords Blog bot DAX Blogs 23 15.12.2015 09:09
mfp: X++ in AX7: Static event subscription Blog bot DAX Blogs 0 11.12.2015 11:11
mfp: X++ in AX7: The var keyword Blog bot DAX Blogs 43 04.12.2015 10:19
mfp: X++ in AX7 Blog bot DAX Blogs 0 02.12.2015 22:13
mfp: "Internal error 25" causes and solutions Blog bot DAX Blogs 0 28.05.2011 01:12
Часовой пояс GMT +3, время: 09:15.
