Старый 15.01.2016, 22:12   #1
emeadaxsupport: DIXF – Cannot Preview source file – CommunicationException – An error occurred while receiving the HTTP response from DMFServiceHelper.svc
Источник: https://blogs.msdn.microsoft.com/axs...icehelper-svc/
Consider a scenario where you are importing data using DIXF, and you get an error when you try to “Preview source file”. 1. The error The error you see looks something like this: System.ServiceModel.CommunicationException: An error occurred while receiving the HTTP response to http://servernamehere:7000/DMFServic...viceHelper.svc. This could be due to the service endpoint binding not using the... Read more
emeadaxsupport: Calling AX 2012 Business Logic from SSIS Using a Script Task and Custom Web Service Blog bot DAX Blogs 0 12.11.2015 03:48
emeadaxsupport: DIXF - Importing Data - How to establish which rows you need to look at when you aren't able to import every row in your input file Blog bot DAX Blogs 0 08.10.2015 15:11
DynamicsAxSCM: Receiving a pallet with mixed items based on a packing structure using License plate receiving mobile device menu item Blog bot DAX Blogs 0 18.09.2014 22:12
emeadaxsupport: Moving POS dlls from one machine to another causes the file to be blocked. Blog bot DAX Blogs 0 29.01.2014 22:12
Microsoft Dynamics CRM Team Blog: Importing two or more entities from a Single File Blog bot Dynamics CRM: Blogs 0 09.11.2010 19:05
Часовой пояс GMT +3, время: 13:21.
