Старый 22.04.2016, 16:11   #1
emeadaxsupport: How to cancel an exchange adjustment
Источник: https://blogs.msdn.microsoft.com/axs...ge-adjustment/
There can be situations where you need to cancel an exchange adjustment. This could be because the wrong exch.rate was applied or because you in hindsight find out it would lead to reconciliation issues if you did not do the reevaluation from the ‘right’ module. Here I will show an example of how to cancel... Read more
emeadaxsupport: How to fix error when running AX 2012 reports: "An exchange rate cannot be found for exchange rate type ZZZ between currencies XXX and YYY on exchange date" Blog bot DAX Blogs 0 06.05.2015 23:13
emeadaxsupport: How to Void/Cancel/Reverse an Accounts Payable Payment that does not a have check number such as ACH, Wire or Electronic Payments in Microsoft Dynamics AX 2012. Blog bot DAX Blogs 0 23.08.2013 22:12
emeadaxsupport: How to perform foreign currency revaluation in Consolidation company to satisfy reporting requirements Blog bot DAX Blogs 0 16.10.2012 22:11
emeadaxsupport: "An exchange rate cannot be found for exchange rate type XXX between currencies YYY and ZZZ on exchange date." when you attempt to process in Microsoft Dynamics AX 2012 Blog bot DAX Blogs 0 26.09.2012 07:15
How to remove exchange adjustment transactions? ginmur DAX in English 5 12.10.2007 17:52
Часовой пояс GMT +3, время: 01:09.
