Вернуться   AXForum > Microsoft Dynamics NAV > NAV: Прочие вопросы
Старый 12.04.2005, 18:11   #1
Functions to get Documentation lines from binary object.
In attached object you can find functions, which get Documentation lines directly from binary object (exported from Object BLOB). You can use this functions to create some versioning tools or autodocumentation.
Marks for finding documentation in binary object I found with comparing some objects.
May be, that it is not exactly, but I did not found case when it will be wrong.
File export was used but Stream can be used too.
Attached object is form 99990 with Object table. You can select some object and use Button "Show documentation" - message with Documentation lines from selected object will be displayed (for example on object Form 99990).
Version 1.1:
Fixed problem with lines like '------------------' etc.
Fixed forgotten link to some table...
http://www.mibuso.com/dl.asp?FileID=343&Type=file
Часовой пояс GMT +3, время: 21:27.
