		#1 |
			 Member
			Читал тренинг. Много думал...
			Тренинг по финансам 4.0 (часть 1 глава 2, если точнее).
			Речь идет о форме плана счетов. Конкретно о поле Проверка кода валюты. " ... 12. Determine how the Currency should be validated for posting, in the Validate currency code list. The choices include the following: ... – To be filled in ? Microsoft Dynamics AX 4.0 verifies the Currency field is completed for posting. The value is not checked. ... " А что, в LedgerTrans или LedgerBudget можно что-то написать с пустой валютой в рамках стандартной функциональности? Дальше речь про поле Проверка пользователя. " ... 14. Determine how User ID should be validated for posting, in the Validate user list. The choices include the following: – Optional ? Microsoft Dynamics AX 4.0 does not verify that the Approved by field in the general journal is completed for posting. This is the default. – To be filled in ? Microsoft Dynamics AX 4.0 verifies the Approved by field is completed for posting. The value is not checked. – Table ? Microsoft Dynamics AX 4.0 verifies the Approved by field is completed for posting, and the value corresponds with the value specified in the ledger account. – List ? Microsoft Dynamics AX 4.0 verifies the Approved by field is completed with one of the user values that are defined on the Validation list button. ... " Что за "Approved by field"?
	С уважением, glibs®  |
