#1 |
mscrm4ever: CRM 4.0 Changing Tab Order
Источник: http://mscrm4ever.blogspot.com/2009/...tab-order.html
============== A while back i posted a solution for changing vertical tabbing to horizontal tabbing. The code ran a bit slow with lookups and so the code below is a revision of the previous posting with the fix. function OnCrmPageLoad() { ReArangeTabIndex(); } function ReArangeTabIndex() { for( var i = 0 ; i < crmForm.all.length ; i++ ) { var element = crmForm.all[ i ]; if (element.tabIndex) { if (element.className == "ms-crm-Hidden-NoBehavior" || element.tagName == "A") { continue; } element.tabIndex = 1000 + (i*10); } } } OnCrmPageLoad(); Источник: http://mscrm4ever.blogspot.com/2009/...tab-order.html
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
