Старый 12.12.2009, 03:11   #1
Microsoft Dynamics CRM Team Blog: Behavior Change in Cascading Assign for Microsoft Dynamics CRM 4.0
Источник: http://blogs.msdn.com/crm/archive/20...s-crm-4-0.aspx
The functionally in Cascading Assign has changed in Microsoft Dynamics CRM 4.0, Update Release 8 or newer . As originally designed, only those objects meet the cascading rules can participate the cascading operation. For Cascading Assign , there are 4...(read more)
Старый 14.12.2009, 09:51   #2
Артем Enot Грунин is offline
Артем Enot Грунин
Аватар для Артем Enot Грунин
3,912 / 623 (28) +++++++
Записей в блоге: 151
New Behavior
With the CRM version 4 design change for Cascading Assign, all objects in the cascading tree will be collected and processed thusly:
  1. (new) All related objects in the cascading tree are collected including those objects do not meet the cascading rules.
  2. All related objects that meet the cascading rules will be assigned to the new owner of the primary object.
  3. (new) The inherited access rights from all previous owners of the reassigned parent objects will be revoked except those are still shared with the parent objects.
Please note the cascading rule will be broken for the sub-tree if the specific object does not meet the cascading rule with its parent object. All objects in the sub-tree will be treated as no-cascading no matter if the individual object meets the rule with its parent or not.
Моск сломал...
Microsoft Dynamics CRM Team Blog: Top 14 Microsoft Dynamics CRM Sites and Downloads Blog bot Dynamics CRM: Blogs 0 14.07.2008 13:05
Часовой пояс GMT +3, время: 15:01.
