Старый 18.11.2011, 16:11   #1
Limitations Surrounding Fetch XML and Microsoft Dynamics CRM 2011 Online
Источник: http://www.dynamicscare.com/blog/ind...rm-2011-online
Fetch XML has a few limitations still which will quickly surface as you start building reports. You need to be aware of these: You cannot specify left outer joins – e.g. The following is not supported: “Select all Accounts who do not have a related Completed Appointment record” You cannot specify group by/sum queries – e.g. The following [...]
Gareth Tucker: Getting Started with CRM 2011 Online Fetch XML Reporting Blog bot Dynamics CRM: Blogs 0 19.05.2011 23:13
Rahul Sharma: Microsoft Dynamics CRM 2011 Fetch XML based Custom Reports Blog bot Dynamics CRM: Blogs 0 15.04.2011 00:12
Microsoft Dynamics CRM Team Blog: Fetch-Xml based Reports: Bits & Pieces Blog bot Dynamics CRM: Blogs 0 24.02.2011 21:11
Часовой пояс GMT +3, время: 14:12.
