Старый 18.10.2013, 12:11   #1
Gareth Tucker: CRM 2013 New Features: JavaScript Notifications
Источник: http://garethtuckercrm.com/2013/10/1...notifications/
CRM 2013 come with a set of new JavaScript functions that we can use for sending notifications to the user.  There are form notifications and field notifications.  Here’s an example of a form notification at work…
The function below was registered on the OnSave event of my form.   It notifies the user that a Save has occurred and timestamps the notification.  I post 3 notifications to demonstrate the 3 different types available (error, warning and information):
function NotifyOnSave() { var today = new Date(); Xrm.Page.ui.setFormNotification('Error! A Save occured at ' + today, 'ERROR'); Xrm.Page.ui.setFormNotification('Warning! A Save occured at ' + today, 'WARNING'); Xrm.Page.ui.setFormNotification('Information: A Save occured at ' + today, 'INFORMATION');}
Here’s what appears after the Save:
Now, if I make another update and then let another Save occur this is what I get:
It’s a little hard to tell on the screenshot but what has happened is each of those 3 notifications has been posted a second time to the form (note: the UI only shows 3 rows of notification, the user has to scroll down to see the other 6 notifications).  The Information notification appears twice due to the sort order applied by the UI:  Information notifications first, then Error notifications followed by Warning notifications.   This is the default behavior  of setFormNotification().   We have options though, we can assign each notification a unique ID and then we can overwrite a previous notification and avoid duplication in a scenario like this.  Here’s the revised JavaScript (note the unique ID added as a 3rd parameter):
function NotifyOnSave() { var today = new Date(); Xrm.Page.ui.setFormNotification('Error! A Save occured at ' + today,'ERROR','1'); Xrm.Page.ui.setFormNotification('Warning! A Save occured at ' + today,'WARNING','2'); Xrm.Page.ui.setFormNotification('Information: A Save occured at ' + today,'INFORMATION','3');}
If you want to clear a notification you use clearFormNotification() and you identify the notification by its unique ID:
Xrm.Page.ui.clearFormNotification('1');
We also get field notification in CRM 2013.  The syntax for these is:
Xrm.Page.getControl(fieldName).setNotification(message);
Here’s an example where I have added a SUBMIT FOR APPROVAL button to the Command bar on a CRM form and have added JavaScript validation to that button that generates field notifications if certain mandatory fields have not been populated.   Here’s the JavaScript:
function SubmitForApproval() { var AlertRequired = false; if (Xrm.Page.data.entity.attributes.get("new_unitamount").getValue() == null) { Xrm.Page.getControl("new_unitamount").setNotification("Unit Amount must be entered in order to submit for Approval"); AlertRequired = true; } else { Xrm.Page.getControl('new_unitamount').clearNotification(); } if (Xrm.Page.data.entity.attributes.get("new_qty").getValue() == null) { Xrm.Page.getControl("new_qty").setNotification("Qty must be entered in order to submit for Approval"); AlertRequired = true; } else { Xrm.Page.getControl('new_qty').clearNotification(); } if (Xrm.Page.data.entity.attributes.get("new_linetotal").getValue() == null) { Xrm.Page.getControl("new_linetotal").setNotification("Line Total must be entered in order to submit for Approval"); AlertRequired = true; } else { Xrm.Page.getControl('new_linetotal').clearNotification(); } if (AlertRequired == true) { alert('Missing information, please clear all alerts'); } else { alert('Submitted!'); }}
And here’s how it looks when I test with missing data.  First the Alert fires…
And then each field that failed a non-null test is flagged with an Alert icon and the notification text is displayed:
This starts to look a bit ugly when you generate notifications for neighboring fields:
The notification text goes away once you mouse over the message, but the alert icon remains:
I wondered whether I could leave out the notification message and just get the alert icon to appear by just saying:  Xrm.Page.getControl("new_unitamount").setNotification();
Unfortunately, the notification speech bubble still appears so this is not a good approach:
I like the form notifications.  I would try to minimize usage so that no more than 3 form notifications ever appear, any more and they just aren’t visible enough.
I’m not sure I like the field notifications.  I like the fact I can highlight fields with issues but I don’t like the notification speech bubbles that appear.  I guess it works well so long as notifications don’t appear for adjacent fields.  I would give this some consideration when deciding how to layout the fields.
Gareth Tucker: CRM 2013 New Features: Actions Blog bot Dynamics CRM: Blogs 1 17.10.2013 11:50
Gareth Tucker: CRM 2013 New Features: Business Process Flows Blog bot Dynamics CRM: Blogs 0 17.10.2013 04:36
Часовой пояс GMT +3, время: 17:20.
