#1 |
First, let me start by saying that based on the evidence so far: It is. Significantly. A number of the changes to the Dynamics NAV 2013 architecture contribute to the performance boosts that many of the test have shown. To outline some of the changes:
However(!), a few things have surfaced in the course of time that are not as explicitely documented as the changes above, nor as apparent, and might have unexpected side effects. I have collected some of the side effects that you might or not be aware of and that might leave you panicking if not certain what you’re facing.
Consider the following example. This is just an illustration of the problem, constructed on CRONUS extended database: A lot of Inventory transactions are posted through the Item Journal, generating a lot of Post cost to the G/L Entry. After this, when browsing an item list and opening an Item card, the page opens very slowly. After locating the offending query in the SQL profiler and running it isolated in Microsoft SQL Server Management Studio with ‘Include Actual Execution Plan’ option enabled, the plan looks similar to the one shown below: ![]() Each sub-query shows reasonably (small) percentage of cost and no apparent reason for bad execution plan. There are no obvious extreme costs, however there is a Clustered Index Scan here: Looking at the filter that SQL Server applies, namely it filters on “Post Value Entry to G_L”. “Item_No_” = “Item”.”No_”: ![]() Although SQL Server reports Operator Cost as small, it shows CPU Cost in excess of 2.3 in approx. 1.94 executions. So, it is likely scanning the table twice and unfortunately the table has 4,7 million rows. Although it is not obvious from the actual SQL Server execution plan that this is a problem, profiling with the SQL Server Profiler reports the query to use more than 5 seconds of CPU, while doing 131.519 reads to fetch 52 rows: ![]() The reason the Duration is on par with CPU Seconds is that all reads are logical from SQL Server Buffers. Re-issuing the query after adding the supporting index shows this in SQL Server Profiler: ![]() So Reads were reduced by a factor of 100 and (warm) duration was reduced by a factor of 40. As you can see, these poor execution plans are not caused by the SmartSQL. However the fact that the SmartSQL queries don’t cache their results will only amplify the issue. To solve it, we have to tackle the performance of that one isolated query by creating a covering index to improve the execution plan. And no, it won’t help to merely customize the page or change the visibility of the field. As long as it is contained in page metadata (so unless removed from page altogether), it will be calculated. So in short, if you do run into an issue of rather dramatic slowness of a page containing flowfields in Dynamics NAV 2013 or higher, isolating and testing the Flow Field queries separately (focusing on ones with clustered index scan, regardless of cost) should lead you to the culprit fairly quickly. A supporting index should resolve the problem.
Consider the following example: You have added an action that invokes a function in a codeunit, that in turn locks/ modifies the record (typically calling custom posting routine) So OnAction trigger code is, for example, as follows: PostingFunction(Rec); Where PostingFunction is a function (in any object other than the source table). Now, the consequence of the previously mentioned transaction scope change and the fact that you’re locking the record in the function, is that the entire source table (Rec) you passed as a parameter in the example above, is locked. In other words, you’re passing the current record as a parameter, but you are locking the whole table. The behavior would cause more damage than good to change at this point due to all functionality it would affect, so it won’t be changed, but fortunately – if you’re aware of this issue, the solution is very simple: SETSELECTINOFILTER(Rec); //adding this line PostingFunction(Rec); Adding the line above should reduce the scope of locking and leave you with locking just the one record (or selection of records if on a list). This applies to card pages as well.
Example: when we do a FINDSET, a number of records (50, 100...) is retrieved. If it is a larger set it will run until all records are retrieved (or buffer is full), even if only first 10 are actually read by application. Eventually the session goes to sleep and after transaction ends sleeping sessions are removed. So in short, these are merely reflecting NAV data access methods, and are not a problem as such. If you want to reduce these, make sure you’re reading all the rows you’re asking for when using FINDSET, otherwise use FIND(‘-&lsquo or FIND(‘+&rsquo .With thanks to Jesper Falkebo and Jens Klarskov Jensen Jasminka Thunes Microsoft CSS These postings are provided "AS IS" with no warranties and confer no rights. You assume all risk for your use. Источник: http://feedproxy.google.com/~r/Micro...-or-is-it.aspx
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
