Старый 23.09.2016, 10:11   #1
organicax: Resource Capabilities Map
Источник: https://organicax.com/2016/09/22/res...abilities-map/
If you have a lot of resources to manage in production you might want to consider assigning capabilities to them. Once you have done this you can use these to find resources. There is then a form that gives you a handy overview of the resources called the capability map.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Production control
Классы коллекций (инициализация, сериализация): List, Set, Map. petergunn DAX: База знаний и проекты 14 09.07.2025 11:37
organicax: Warehouse mobile device text colors some additional notes on setup Blog bot DAX Blogs 0 25.03.2016 12:11
Microsoft Dynamics CRM Team Blog: Creating Heat Maps with Bing Maps and Dynamics CRM Blog bot Dynamics CRM: Blogs 0 31.10.2012 03:16
emeadaxsupport: Scheduling based on Resource Capabilities in Microsoft Dynamics AX 2012 Blog bot DAX Blogs 0 21.09.2012 05:24
Microsoft Dynamics CRM Team Blog: Custom Charting Capabilities in Microsoft Dynamics CRM 2011 Blog bot Dynamics CRM: Blogs 0 19.01.2011 21:11
Часовой пояс GMT +3, время: 22:10.
