Старый 29.11.2016, 12:11   #1
axmfg: Using the handheld device for reporting serial numbers as finished in production
Источник: https://blogs.msdn.microsoft.com/axm...in-production/
Introduction A new flow for the handheld device has been released with KB article: 3148600. This flow enables the user to register the finished good serial number when reporting as finished in production. This flow is targeting a process where the finished good serial number is generated under the following conditions: It is assigned by...
DynamicsAxSCM: Enable picking of sales serial number items with R3 warehouse management processes Blog bot DAX Blogs 0 07.12.2015 14:11
axmfg: New support for serial number registration in production Blog bot DAX Blogs 0 30.09.2015 11:11
emeadaxsupport: How to Auto generate Serial numbers on a Production order for a serial tracked item Blog bot DAX Blogs 0 26.06.2015 00:19
axmfg: Generating put away work when reporting as finished from the Dynamics AX client Blog bot DAX Blogs 0 23.09.2014 14:11
Часовой пояс GMT +3, время: 05:52.
