Старый 31.01.2017, 23:14   #1
organicax: Create a project budget from a forecast
Источник: https://organicax.com/2017/01/31/cre...om-a-forecast/
If you are setting up projects you can use both or either the forecasts or budgets. They have differing amounts of details that you can use for different purposes through the management of the project. If you have created forecasts then you can copy them to a budget as the foundation for the budget.
Here is a quick overview.
AX2012 R3 Cu11.
Cheers
Lachlan
Filed under: Project management and accounting
organicax: Create a project budget without a forecast Blog bot DAX Blogs 0 31.01.2017 23:14
organicax: Fixed Asset – create from project accounting Blog bot DAX Blogs 0 22.09.2016 13:11
atinkerersnotebook: Create Projects In Dynamics AX Directly From Microsoft Project Blog bot DAX Blogs 0 04.02.2014 19:11
emeadaxsupport: Intercompany time postings incomplete at transaction voucher level when project date differs from the day posted Blog bot DAX Blogs 0 19.08.2013 19:11
Часовой пояс GMT +3, время: 10:48.
