Старый 13.04.2017, 00:13   #1
organicax: Counting adjustment from on-hand inquiry
Источник: https://organicax.com/2017/04/12/cou...-hand-inquiry/
When you are working with inventory sometimes you need to make a quick adjustment to what is on-hand in the system compared to what you see in the physical world. There are a few ways to adjust inventory for example with an inventory adjustment journal or a counting journal. But there is also a quick handy function that you can find on the on-hand lists.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Product information management, Warehouse management
organicax: Counting adjustment from on-hand inquiry Blog bot DAX Blogs 0 13.04.2017 00:13
organicax: Compile of posts on Counting group – Counting codes setup. Blog bot DAX Blogs 0 19.09.2016 14:11
organicax: Counting group – Counting Code – Minimum Blog bot DAX Blogs 0 18.09.2016 04:14
Adjustment = Коррекция, Корректировка, Исправление или еще как? mazzy DAX: Прочие вопросы 4 11.01.2006 10:57
Часовой пояс GMT +3, время: 16:08.
