Старый 26.04.2017, 17:11   #1
emeadaxsupport: What does the Maximum penny difference parameter do?
Источник: https://blogs.msdn.microsoft.com/axs...-parameter-do/
This post will describe the purpose of the General Ledger parameter ‘Maximum penny difference’. This is quite an important parameter, but its purpose is often not clearly understood. Hopefully this post will demystify it ! Suppose your company currency is EUR and you post the following journal The voucher looks as follows This is completely... Read more
emeadaxsupport: Manufacturing Execution in AX 2012: Issue with the "Lock employee"-parameter Blog bot DAX Blogs 0 19.09.2013 18:11
emeadaxsupport: Scheduling Time-out parameter setting in AX 2012 Blog bot DAX Blogs 0 23.04.2013 19:11
emeadaxsupport: "Parameter is missing a value" error running a customized report in Microsoft Dynamics AX 2012 Blog bot DAX Blogs 0 21.11.2012 00:12
axinthefield: Currency Round-off and Maximum Penny Difference Blog bot DAX Blogs 0 20.05.2011 04:13
emeadaxsupport: Error during processing of 'AX_CompanyName' report parameter. (rsReportParameterProcessingError) Blog bot DAX Blogs 1 11.04.2011 18:56
Часовой пояс GMT +3, время: 21:44.
