Старый 12.07.2017, 14:11   #1
palleagermark: New "Retail" model in "July 2017" creating backwards compatibility issues
Источник: http://www.agermark.com/2017/07/new-...-creating.html
The "July 2017" release has a new model called "Retail" and elements have been moved from other models to this model.
Even if you have made your own solutions exclusively with extensions, this might break your build because you might now need to add a reference to the "Retail" model.
But when you add that, you can't build your solution on the "1611" release anymore because build will complain about not knowing the "Retail" model listed in the Descriptor file.
So, even if your code works perfectly on both "1611" and "July 2017", you could have a need to branch out in VSTS to have two different Descriptor files.
dynamicsaxse: May-June 2017 release – Dynamics AX 2012 R3 Blog bot DAX Blogs 0 21.06.2017 00:12
stoneridgesoftware: Dynamics 365 for Operations: How to Create a New Model Blog bot DAX Blogs 0 11.02.2017 01:11
emeadaxsupport: The INSERT statement conflicted with the FOREIGN KEY constraint "FK_ModelElementData_HasModelId_LayerId". The conflict occurred in database "YourDataBaseName_model", table "dbo.Model" Blog bot DAX Blogs 0 23.05.2014 13:11
Часовой пояс GMT +3, время: 00:00.
