Старый 08.08.2017, 10:11   #1
organicax: Setting up an environment to try the PowerBI report models – Part 4
Источник: https://organicax.com/2017/08/07/set...models-part-4/
In a previous post we had a look at setting up the data gateway to allow PowerBI.com to access the data and published the report model. Now that the report is accessible in PowerBI.com we can access it from the D365 client. In the platform update you will find a new option to open the report catalog. From here you can locate content and link it to your workspace. This allows the user to do transactional work but also investigate the data without having to go to another interface.
D365 July 2017 Update 8 (7.0.4565.16211)
Cheers
Lachlan
Filed under: Business intelligence
organicax: Setting up an environment to try the PowerBI report models – Part 3 Blog bot DAX Blogs 0 08.08.2017 03:38
organicax: Setting up an environment to try the PowerBI report models – Part 2 Blog bot DAX Blogs 0 08.08.2017 03:38
organicax: Setting up an environment to try the PowerBI report models – Part 1 Blog bot DAX Blogs 0 08.08.2017 03:38
Часовой пояс GMT +3, время: 12:27.
