Старый 01.11.2017, 09:11   #1
daxmusings: PSA: AX7 Build Failure on Generate Packages / Model Export
Источник: http://feedproxy.google.com/~r/Dynam...-generate.html
More and more customers are seeing an error in the "Generate Packages" build step on their AX7 automated builds. The build shows as "Partially Succeeded" and the step that generates packages shows a problem.
The following error is shown in the build summary:
Error generating deployable packages: Error:
Unexpected exit code from model export: 1
At C:\DynamicsSDK\GeneratePackage.ps1:523 char:5
And going into the logs, the following details are shown:
- Foundation Upgrade: Exporting model source...
- Command: J:\AosService\PackagesLocalDirectory\Bin\ModelUtil.exe -export -metadatastorepath="J:\AosService\PackagesLocalDirectory" -modelname="Foundation Upgrade" -outputpath="C:\DynamicsSDK\VSOAgent\_work\1\Packages\Source"
Model Foundation Upgrade was not found in the specified Metadata Store
- Foundation Upgrade: Model export completed with exit code: 1
- Exception thrown at C:\DynamicsSDK\GeneratePackage.ps1:216: throw "Error: Unexpected exit code from model export: $ModelUtilExitCode"
System.Management.Automation.RuntimeException: Error: Unexpected exit code from model export: 1
Error generating deployable packages: Error: Unexpected exit code from model export: 1 At C:\DynamicsSDK\GeneratePackage.ps1:523 char:5
The automated build has an optional (turned on by default) to not just create the deployable package but also produce an export of all the models it built. The way this is done is it looks at any descriptor files for any models in source control, and those are the ones being exported (since those are also models for which their containing package are built).
That said, it appears many customers add the whole Descriptor folder to source control when over-layering existing packages. In itself this doesn't matter since the only extra work this creates is the model exports, it doesn't add any extra compile time since any one of the descriptors would cause the whole package to recompile.
The problem lies in the "Foundation Upgrade" model. This is an old artifact and this model is actually "Disabled" (a flag in the descriptor file). As such, our metadata APIs ignore this model - you will notice even though the descriptor and model are in your packages folder, this model is not showing up in the AOT. So, when the build tries to export this model, the model utility asks the metadata API for the model, and the API says it doesn't exist...
The fix of course is easy. The build scripts will be updated to double check the flag and not try to export disabled models. For customers or partners running into this issue today the answer is also easy - just remove the "foundation upgrade.xml" file from your source control. Note that this will trigger the deletion of that file on any dev boxes as well, but that is not an issue since this model isn't loaded or used anyway. A conversation has also started to see if this model should be downright removed in the next application release.
daxmusings: Pointing Your New Build Definition to a Different Branch Blog bot DAX Blogs 0 14.09.2017 13:11
stoneridgesoftware: Dynamics 365 for Operations: How to Create a New Model Blog bot DAX Blogs 0 11.02.2017 01:11
daxmusings: Pointing Your New Build Definition to a Different Branch Blog bot DAX Blogs 0 03.11.2016 03:34
daxmusings: Design-Compile-Run Part4: Paradigms in AX7 Blog bot DAX Blogs 0 25.05.2016 10:11
emeadaxsupport: Unable to import model files generated using Export-AxModel cmdlet, or upload it to LCS for Customization analysis Blog bot DAX Blogs 0 05.12.2014 19:11
Часовой пояс GMT +3, время: 06:22.
