Старый 02.01.2018, 14:12   #1
sinedax: Deploy SSRS Reports Manually - Dynamics 365 for Finance & Operations On Premises Installation
Источник: http://sinedax.blogspot.com/2018/01/...-dynamics.html
Hi All and Happy 2018!!
In an D365FO On Premise Installation you can raise an issue where the SSRS Reports are not deployed.
From my understanding it should be a Bug that will be fixed soon.
However, you can deploy them manually following the below steps:
  • Go to the SSRS nodes.
  • Access to the C:\ProgramData\SF\Rep_xx\Fabric\work\Applications\ReportingService_Appxx\ReportingBootstrapperPkg.Code.x.x.x.xxxxxxxxxxx\Scripts folder
  • Open PowerShell in Admin Mode. So Click on the File menù\Open Windows PowerShell\Open Windows PowerShell as Administrator
  • .\DeployAllReportsToSSRS -PackageInstallLocation \\AOS1SERVERNAME\c$\ProgramData\SF\AOS_xx\Fabric\work\Applications\AXSFType_Appxxx\AXSF.Code.x.x.x.xxxxxxxxxxx.zip.0\Packages -ReportServerIp XX.XX.XX.XX
Till soon!
sinedax: The client id must be unique across all clients - Dynamics 365 for Finance & Operations On Premises Installation Blog bot DAX Blogs 0 30.10.2017 03:36
sinedax: Microsoft Dynamics 365 for Finance & Operations - Change the standard URL in a VHD Machine Blog bot DAX Blogs 0 21.10.2017 14:17
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 14 Blog bot Dynamics CRM: Blogs 0 12.07.2013 07:13
Часовой пояс GMT +3, время: 01:23.
