Старый 02.04.2018, 17:11   #1
ievgensaxblog: MSDyn365FO. How to switch from IIS Express to IIS on development VM.
Источник: https://ievgensaxblog.wordpress.com/...evelopment-vm/
All new environments starting from PU12 are using IIS Express in debug mode and often due to random issues we have to restart it using “Restart IIS Express” option in the Dynamics 365 menu. There are multiple discussions on community and yammer forums regarding these issues and Joris de Gruyter mentioned that it is possible to switch back to IIS if you have admin access (environment deployed to customer’s or partner’s own Microsoft Azure subscription), but did not explain how
All we need to do is to edit DynamicsDevConfig.xml file that could be found in ‪K:\AosService\PackagesLocalDirectory\Bin folder (drive letter could be different for your VM). Change RuntimeHostType value from IISExpress to IIS and that’s all.
You may find same file under %userprofile%\Documents\Visual Studio 2015\Settings\ , however, Visual Studio rolls back any changes to RuntimeHostType if value is different to value in \AosService\PackagesLocalDirectory\Bin\DynamicsDevConfig file, so don’t try to change it for individual user.
stoneridgesoftware: How to View Product Attributes from a Release Product in Dynamics 365 for Finance and Operations Blog bot DAX Blogs 0 15.03.2018 18:11
emeadaxsupport: How to print BOL from Transportation Management without using Warehouse Management Blog bot DAX Blogs 0 12.03.2015 18:11
bojensen: How to read from the Windows event log from Dynamics Ax Blog bot DAX Blogs 0 03.02.2015 14:11
furnemont: How-to series: Send SMS messages from CRM 2011 (part 2) Blog bot Dynamics CRM: Blogs 0 13.06.2011 12:11
Часовой пояс GMT +3, время: 13:25.
