#1 |
alirazazaidi: Updating Date Effective Tables in AX 2012, Dynamics 365 for finance and operations
Источник: https://www.tech.alirazazaidi.com/up...nd-operations/
============== I was struggling to update Date Effective Table in Dynamics Ax 2012 R3. At least one hour of struggle, finally I update the required record. Only good post which helps is by Agnela GoldBrg. http://ibisinc.com/blog/updating-dat...es-in-ax-2012/ One line tip from this post is on Date Effective table, The active record reference can be get with of DateTimeUtil::utcNow() Its really small tip, yes learning and solving problem at hand waste hours. Lets take a real world example We have to update Job detail with X++. For HCMJobDetail table following way works for me. hcmJobDetail= HcmJobDetail::findByJob(hcmJob.RecId,DateTimeUtil::utcNow(),DateTimeUtil::utcNow(),true);We can query on required table with following way The complete code snippet which works for me is here. Источник: https://www.tech.alirazazaidi.com/up...nd-operations/
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
