Старый 03.08.2018, 18:11   #1
d365technext: Financial dimension configuration for integrating D365FO
Источник: http://d365technext.blogspot.com/201...ation-for.html
Financial dimension configuration for integratingD365FO
Today, A bug reported to me that complete segments Default Dimensions are not exporting using Data Entity...
Functional share more detail with me Like, they set the default dimension with Positions.
Dimension have 9 segments but while they are exporting using data management framework then 5 dimension segment are missing in Excel sheet..
Entity Name > Position default dimensions
Here is the screen shot of position and the set of dimension.
Dimension set
Functional Create Export Project and Export the data and download the file
downloaded file screenshot
Resolution
After spending hours of hours and debugging in the code, finally we found that this is configuration issue and there is template configuration form available for Dimension Integration..
General Ledger>Chart of accounts>Dimensions>Financial dimension configuration for integrating
Here We define segment which we need to export via integration.....
Navigate to Financial Dimension Configuration for Integration
Select Dimension in which you want to change...
Default are 4 Dimension were set in my case and the same were exporting..
Move your required segment from left to right list page.. for demo purpose i have moved all segment.
Save the record a confirmation prompt show on your screen... click on yes.
Now Execute the Export project and download the export file...
Here is the final result... After changing in
Dimension configuration working fine for me ...
Please feel free to contact me In case of any issue you are facing during implementation of this blog
ax_gfm_framework_team: Dimension defaulting in accounting distributions, Part 3 - Splitting and defaulting using Financial dimension default templates and Main account allocation rules Blog bot DAX Blogs 0 18.12.2013 09:11
sumitsaxfactor: Replacing Financial Dimension in Ledger Dimension Blog bot DAX Blogs 0 19.01.2012 13:11
Khue Trinh: Setting up a link between a financial dimension and the site inventory dimension Blog bot DAX Blogs 0 27.09.2010 13:05
Inside Dynamics AX 4.0: Licensing and Configuration Blog bot DAX Blogs 0 31.10.2007 11:40
Часовой пояс GMT +3, время: 03:31.
