Старый 15.01.2019, 12:11   #1
ievgensaxblog: MSDyn365FO. AX 2012 data upgrade with virtual companies.
Источник: https://ievgensaxblog.wordpress.com/...ual-companies/
In Dynamics 365 for Finance and Operations virtual companies are deprecated and could not be upgraded according to the documentation that just state this fact without proposing a solution.
If we cannot upgrade, then we need to get rid of them. Here are the high level steps how you can de-virtualize a table. Let’s say that we have virtual company V with two companies: A and B. V has only one table collection with one table for simplicity, let’s call it Table1.
<ol>Delete a data from Table1 that belongs to the companies A and B. When you create a virtual company, you may already have some data in the tables you want to share. That data may be orphaned, so we want to delete it to avoid duplicates. Can be done via simple T-SQL script:DELETE FROM Table1WHERE DATAAREAID = 'A' or DATAAREAID = ‘B’
Go to System administration > Setup > Virtual company accounts and delete the virtual company.
Restart AX client.
Insert data from the virtual company to de-virtualized companies via X++ job:static void deVirtualizeTables(Args _args){ DataAreaId virtualDataAreaId = 'V'; container oldCompaniesCon = ['A', 'B']; VirtualDataAreaList virtualDataAreaList; void deVirtualizeTable(TableId _tableId) { int i; DataAreaId dataAreaId; SysDictTable dictTable = new SysDictTable(_tableId); Common buffer = dictTable.makeRecord(); Common newBuffer; while select crossCompany buffer where buffer.dataAreaId == virtualDataAreaId { for (i = 1; i
Старый 16.01.2019, 06:23   #2
TasmanianDevil is offline
TasmanianDevil
Мрачный тип
Аватар для TasmanianDevil
887 / 389 (14) ++++++
Круто, чо уж там ...
А если дело касается завиртуаленной таблицы, являющейся источником для определенного сегмента DefaultDimension или LedgerDimension ?
За это сообщение автора поблагодарили: trud (5).
Старый 16.01.2019, 09:12   #3
skuull is offline
skuull
700 / 752 (27) +++++++
Это не подходит для таблиц со связью по recId. Там придётся после вставки записей назад в старые компании пройтись и перебить все ссылки на новые recId. Для аналитик должно тоже сработать, но я не пробовал.
Старый 16.01.2019, 10:46   #4
trud is offline
trud
1,039 / 1635 (57) ++++++++
Кстати хорошее замечание от TasmanianDevil - т.е. лучше использовать немного другой алгоритм - перебить значение виртуальной компании на реальную в SQL, и дальше это уже размножить. В этом случае корректная ссылка по RecId останется хотя бы в одной компании
Старый 16.01.2019, 11:30   #5
TasmanianDevil
Мрачный тип
В остальных компаниях - будут интеллектуальные трэш, угар и содомия в одном флаконе по части копирования туда таблицы-источника, генерации новых комбинаций аналитики по новым значениям таблицы-источника и обновления имеющихся ссылок на новые ссылки по новым комбинациям. При наличии более одной такой таблицы - степень "радости" возрастает в геометрической прогрессии.
Кому они, виртуальные компании, <censored>, мешали?
Старый 16.01.2019, 12:21   #6
trud is offline
trud
А зачем новые комбинации генерить? Аналитики и так были не company specific.
The primary table that is to be used as a source of financial dimension data MUST have a unique natural key value of 30 characters or less, and that value MUST resolve to a single RECID within that table.
Виртуальные компании заменились Cross-company data sharing, т.е. тут типичный Not Invented Here синдром
За это сообщение автора поблагодарили: EVGL (3).
Старый 16.01.2019, 13:13   #7
skuull is offline
skuull
Не все так однозначно, есть еще такое https://docs.microsoft.com/en-us/dyn.../copy-customer
Старый 17.01.2019, 05:47   #8
TasmanianDevil
Мрачный тип
Согласен, про комбинации погорячился (больше года не работал уже с этой "прелестной" поганью, подзабыл ужо чутка структуру) - только записи в DimensionAttributeValue , ссылающиеся на записи в виртуализированном справочнике, покорежить придется в остальных компаниях, что в принципе снижает степень проблемы.
Старый 19.01.2019, 07:30   #9
Alex_KD is offline
Alex_KD
AxAssist
522 / 362 (14) ++++++
Прежде чем присоединись к критике, хочу сказать что автор сделал больше чем МС в этом направлении.
Можно (Insert + Delete) свести к одному Update.
Я бы весь скрипт написал в T-SQL - проще, быстрее, можно повторить во всех средах (dev/qa/prod).
У нас теже проблемы с использование Partition. У нас их 6 и апгрейд не подерживается МС.
Проблему решил SQL скриптами - копируем все данные в новую базу и менять копируемый partition на initial (плюс 200 табличек у которых нет partition).
Старый 20.01.2019, 03:40   #10
trud is offline
trud
Сообщение от Alex_KD Посмотреть сообщение
А как такой скрипт написать в SQL?
"newBuffer.doInsert();" требует же выделения нового RecId, т.е. как-то в SQL его надо будет выделять
Старый 20.01.2019, 04:01   #11
skuull is offline
skuull
Играясь с SYSTEMSEQUENCES таблицой, первый попавшийся блог с примером
https://sumitsaxfactor.wordpress.com...in-sql-server/
Не то что это сильно проще
Старый 20.01.2019, 04:05   #12
skuull is offline
skuull
Чисто из вредности спрошу, чем 2 SQL скрипта и 1 x++ джоб проигрывают в повторяемости во всех средах ? Да. там больше ручных действий, но если идти по списку то какая принципиальная разница?
Старый 20.01.2019, 14:18   #13
trud is offline
trud
Кстати вот эта конструкция перезапишет значения в полях CreatedDateTime, а оно иногда нужно. Т.е. нужно усложнять
buf2buf(buffer, newBuffer);
Старый 20.01.2019, 21:14   #14
skuull is offline
skuull
А можно сценарий, когда оно нужно? Для расширения кругозора.
Старый 21.01.2019, 06:11   #15
trud is offline
trud
Ну довольно часто нужно, эту информацию часто показывают пользователям - дата и время создания, кто создал. Встречал также что кто-то даже отчеты строит по этим полям
Старый 21.01.2019, 10:05   #16
AlexeyS is offline
AlexeyS
404 / 339 (12) ++++++
Скрипт на T-SQL иногда быстрее и проще в разы, но в D365 MS не дает доступа на ПРОД базу SQL.
Старый 22.01.2019, 03:08   #17
Alex_KD is offline
Alex_KD
AxAssist
Код типа такого должен работать -
Код:
declare @newDataAreaId as nvarchar(4) = 'BBBB'
declare @virtualDataAreaId as nvarchar(4) = 'V'
insert into [Table1]
  [RECID]
, [DATAAREAID]
...list of fields...
 SELECT
  [RECID] = row_number() over (order by (select NULL)) + (select isnull(max(RECID), 0) from [Table1] )
, [DATAAREAID] = @newDataAreaId
, ...list of fields...
  FROM [Table1] as [sourceTable]
 WHERE [sourceTable].DATAAREAID = @virtualDataAreaId
Почему не SYSTEMSEQUENCES? Потому что D365 использует SQL sequence для выделения RecId и про SYSTEMSEQUENCES можно забыть как пережиток прошлого.
Data upgrade создаст все SQL sequence для RecId автоматически (см. DataUpgradePackage\AOSService\Scripts\AutoMajorDataUpgradePreReqs.ps и AdjustSQLSequences.sql).
Скрипт делает select max(RecId) по всем таблицам, так что опять, что там в SYSTEMSEQUENCES неважно.
Скрипты для AX2012.
Сообщение от skuull Посмотреть сообщение
Вас while select + doInsert не смущает? Изменение-копирование данных - это для SQL, если надо бизнес логику - тогда X++ job.
Плюс, а сколько там других шагов будет которые тоже вручную делать?
По мне так на go-live день чем меньше шагов, тем лучше -
Потушил AOSы (вручную),
Запустил скрипт -
DB back up, подготовка дынных (например virtual companies), скрипты от МС для подготовки bacpac, сам bacpac, залив bacpac в блоб, restore в sandpit, создание сервисных аккаунтов.
Как скрипт отработал - запуск D365 upgrade.
А сколько раз вы эти шаги будете делать перед реальным go-live?
Тоже чисто из вредности спрошу, а вы код релизите через xpo вручную?
За это сообщение автора поблагодарили: trud (3).
Старый 22.01.2019, 06:35   #18
skuull is offline
skuull
Неа, что должно смущать?
Это экспертное мнение или есть какие-то обоснования?
Запустил скрипт -
Простой же был вопрос, почему 3 скрипта не повторяемые, а 1 повторяемый? Там и там есть ручные шаги, какой у вас критерий "повторяемости"?
Хорошо когда можно через model store, но не всегда это возможно. Какое это отношение вообще имеет к теме дискусии?
axsa: Extensibility in Dynamics AX 2012 R3 CU8 (CRT, RetailServer, MPOS) Part 2 – New data entity Blog bot DAX Blogs 0 21.05.2015 01:19
axsa: Microsoft Dynamics AX 2012 Data Import/Export Framework standalone version for AX 2012 R2 without installing full CU7 Blog bot DAX Blogs 0 04.12.2013 04:13
emeadaxsupport: SEPA affected objects Blog bot DAX Blogs 0 29.11.2013 13:11
emeadaxsupport: Writing Data Upgrade Scripts Part 1: Understanding the components of the process Blog bot DAX Blogs 0 10.02.2012 05:16
Часовой пояс GMT +3, время: 21:19.
