|  31.01.2019, 18:12 | #1 |
| Участник | kurthatlevik: MPOS – Open full (kiosk) screen mode when having dual display
			Источник: https://kurthatlevik.com/2019/01/31/...-dual-display/ ============== For a retailer, every saved “click” is appreciated, and the ability to remove any noise appreciated. When starting MPOS in maximum mode, you will often see that you have a title bar at the top, and the app-bar at the bottom.   In windows 10 you can also use the “tablet-mode” to get the MPOS into full screen mode. BUT! If you have a dual display setup, it the tablet mode does not work. If you want to remove them, there is a smart keyboard short-cut: Shift-Windows-Enter This will put the MPOS in full screen mode, and giving a nicer appearance without the bar’s. Then the questions is how to make this always happen, when starting the MPOS ? This was actually not a easy task, but a colleague of me (Espen) made it possible , du using a powershell script. The following page contains a small powershell script, that opens a UWP app in full (kiosk) screen mode:   Add this to a “start up folder”, and create a new powershell script containing ; [Path]\StartUWPAppFullScreen.ps1 -app Shell:Appsfolder\Microsoft.Dynamics.Retail.Pos_tfm0as0j1fqzt!App Then create a shortcut towards this new powershell app. How initial investigations (by Sven Erik) shows that the MPOS app ID is Microsoft.Dynamics.Retail.Pos_tfm0as0j1fqzt!App and let’s hope this ID stay’s permanent. Then the MPOS looks nicer for the user, without noice.   Источник: https://kurthatlevik.com/2019/01/31/...-dual-display/
				__________________ Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
