#1 |
axtoday: Chain of Command - avoiding the next call
Источник: http://axtoday.blogspot.com/2019/02/...next-call.html
============== This is possibly something that needs to be used very sparingly if at all, but apparently there is a way (up until the latest version - v8.1) to avoid calling the next() call when using chain of command. The key is to use double nested conditions: //this will not work "call to 'next' should be done only once and unconditionally" protected voidchooseLinesPackingSlip(boolean _append) { If (true) { this.somethingElse(_append); return; } nextchooseLinesPackingSlip(_append); } //this will work protected void chooseLinesPackingSlip(boolean _append) { If (true) { if (true) { this.somethingElse(_append); return; } } next chooseLinesPackingSlip(_append); } Источник: http://axtoday.blogspot.com/2019/02/...next-call.html
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
