#1 |
crmtipoftheday: Tip #1268: Restrict CDS instance creation
Источник: https://crmtipoftheday.com/1268/rest...ance-creation/
============== With P2 licensing, can you control who can spin up a CDS instance via Azure Active Directory since each license comes with 2 CDS instances? (we don’t want hundreds of CDS instances cluttering up our tenant) Via set-TenantSettings example towards end of the posttl;dr How to govern environment creation Download and install the admin powershell cmdlets as described here. Read more about our cmdlets here. $settings = @{ DisableEnvironmentCreationByNonAdminUsers = $true }Set-TenantSettings $settingsNote for PowerApps/Flow customers – If you use the new flag to restrict the environment creation, only tenant admin will have the ability to create new environments. Personally, I like the suggestion that the default should be Opt-in not Opt-out. Or, as one of the commentators put it succinctly: How quickly can I change that setting to false Cover photo by unsplash-logoAlice Achterhof Источник: https://crmtipoftheday.com/1268/rest...ance-creation/
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
