Старый 02.07.2019, 17:11   #1
ievgensaxblog: MSDyn365FO. How to Import CSV file using Electronic Reporting. Part 5 – Run import from X++ code.
Источник: https://ievgensaxblog.wordpress.com/...t-from-x-code/
In previous 4 parts I showed how to build new format without a line of X++ code, but unfortunately to run it you must go to ER workspace. However, it is possible to run it from X++ as well, code below could be easily invoked from a new button to give users better experience.
var runner = ERObjectsFactory::createMappingDestinationRunByImportFormatMappingId(_mappingId, _integrationPoint);runner.withParameter(inputParameters); //optional, to pass parameters if requiredrunner.run();MappingId is import format configuration. Usually, you have a parameter where a user can select configuration, for example, import format configuration field on bank statement format table.
IntegrationPoint is a string value that you populate on the model mapping designer screen:
Usually, format is classStr(ERTableDestination) + ‘#’ + tableStr(TargetTable)
InputParameters is an instance of ERModelDefinitionDatabaseContext class, where you can add parameter name and value pairs:
ERmodelDefinitionInputParametersAction inputParameters = new ERmodelDefinitionInputParametersAction();inputParameters.addParameter('$ExecutionID', _executionID).addParameter('$AccountId', bankAccount);
ievgensaxblog: MSDyn365FO. How to Import CSV file using Electronic Reporting. Part 3 – Map format to model. Blog bot DAX Blogs 0 06.02.2019 07:12
erconsult: Electronic Reporting (ER) Cookbook 2: new tips from the kitchen Blog bot DAX Blogs 0 06.08.2018 17:11
furnemont: How-to series: Send SMS messages from CRM 2011 (part 3) Blog bot Dynamics CRM: Blogs 0 13.06.2011 12:11
Часовой пояс GMT +3, время: 15:55.
