Старый 31.05.2020, 00:20   #1
palleagermark: Using the product configurator in integration scenarios
Источник: https://www.agermark.com/2020/04/usi...urator-in.html
Product configuration in D365FO must happen through the user interface, as the product configuration form is the only piece of code that communicates with the solver, wrapped in a dll outside D365FO's X++ codebase. The communication happens through the JavaScript of a designated form control. This is not great if you want to create a configuration in integration scenarios.
In AX 2012 R3 CU8 a class was introduced to allow you to pass a set of attributes and values for these, without using UI parts, and then get the solver to return the XML needed for processing in the backend engine. The class is named PCRuntimeSynchronousConfigurator and you can read a bit about it here.
Even though the solver dll basically is the same between AX 2012 and D365FO, this class didn't make it to D365FO. Well until now, where the class is included in 10.0.12.
So here is an example of how to generate configuration XML for the backend engine:
<div>public static void main(Args _args)
PCProductConfigurationModel productConfigurationModel =
PCProductConfigurationModel::findByName('High End Speaker (D0004)');
str modelXML = productConfigurationModel.getXML();
System.String values;
values = '' +
DynamicsAxSCM: Understanding the product validation process in Dynamics AX 2012 Blog bot DAX Blogs 0 07.12.2012 03:12
DynamicsAxSCM: Using product templates in Dynamics AX 2012 Blog bot DAX Blogs 1 24.09.2012 11:05
DynamicsAxSCM: Product-item data management services Blog bot DAX Blogs 0 06.07.2011 17:11
dynamics-ax: Product Management with Microsoft Dynamics AX 2012 - Part III Blog bot DAX Blogs 0 17.05.2011 17:11
dynamics-ax: Product Management with Microsoft Dynamics AX 2012 - Part II Blog bot DAX Blogs 0 11.05.2011 06:15
Часовой пояс GMT +3, время: 10:16.
