Старый 17.01.2021, 21:13   #1
ax.docentric: Comment on Use SMTP4DEV for testing emails without sending in D365FO by Jürgen Weber
Источник: https://ax.docentric.com/use-smtp4de.../#comment-1817
Nice post! Thank you very much for this information.How does that work with the configurable business documents in D365 and the use of ER reporting destinations?I mean if we setup the e-mail output not with print management but with ER reporting destinations.Is it the same behavior with the smtp4dev?I would hope so, but you are referring to "SSRS Email print destination but in this article, we will rather focus on the Email print destination improved by Docentric"
ax.docentric: Comment on Create a new custom report in D365FO using Docentric by Ana Blog bot DAX Blogs 1 10.11.2020 19:11
ax.docentric: Comment on Configure a safe connection to D365FO in OneBox by CT Blog bot DAX Blogs 0 28.08.2019 15:11
emeadaxsupport: AX Performance Troubleshooting Checklist Part 2 Blog bot DAX Blogs 0 09.09.2014 16:11
Часовой пояс GMT +3, время: 20:51.
