Старый 22.03.2021, 11:11   #1
ax.docentric: Comment on Configure SharePoint Online integration in D365FO OneBox by Klemen Novak
Источник: https://ax.docentric.com/configure-s.../#comment-2169
In reply to Nguyễn Thành Được.Hi Nguyễn,Please install the Connect-MsolService using the following steps:- Go to PowerShell as Administrator on your OneBox machine- Run the command: Install-Module MSOnline- Run the command: Install-Module AzureADAfter the successful installation the command Connect-MsolService should be working as expected.Hope that this helps.Kind regards,Klemen
ax.docentric: Comment on Check execution in batch in Print management in D365FO by Miha Vuk Blog bot DAX Blogs 1 22.12.2020 18:14
ax.docentric: Comment on Append Terms and Conditions to printed Purchase orders or Invoices in D365FO by bablu Blog bot DAX Blogs 0 23.01.2019 11:11
Microsoft Dynamics CRM Team Blog: Impact of Dynamics CRM December 2012 Service Update and SharePoint Online Service Update on CRM-SharePoint Integration Blog bot Dynamics CRM: Blogs 0 09.01.2013 01:11
Часовой пояс GMT +3, время: 16:24.
