Старый 12.12.2021, 11:11   #1
dynamicsaxinsight: AX 2012: Handling CLR exceptions
Источник: https://dynamicsaxinsight.wordpress....lr-exceptions/
Purpose:
The purpose of this post is to demonstrate how can we effectively handle CLR exceptions.
Application:
Dynamics AX 2012
Business requirement:
To report CLR inner exception.
Solution:
Please find the code below to get the inner CLR exception.
Code
private void getFiles(){ System.String[] files; System.Collections.IEnumerator enumerator; str file; ; try { fileSet = new Set(Types::Container); files = System.IO.Directory::GetFiles(filePath, '*.csv'); enumerator = files.GetEnumerator(); while (enumerator.MoveNext()) { file = enumerator.get_Current(); fileSet.add([file]); } } catch (Exception::Internal) { this.processCLRErrorException(); } catch (Exception::CLRError) { this.processCLRErrorException(); }}
private void processCLRErrorException(boolean _throw = true){ CLRObject exc; CLRObject innerExc; CLRObject clrExcMessage; str strError; ; exc = CLRInterop::getLastException(); if (exc) { innerExc = exc.get_InnerException(); clrExcMessage = exc.get_Message(); while (innerExc != null) { innerExc = innerExc.get_InnerException(); clrExcMessage = innerExc.get_Message(); } strError = CLRInterop::getAnyTypeForObject(clrExcMessage); error(strError); if (_throw) { throw error("Update has been cancelled"); } }}
dynamicsaxse: November 2017 Release – Dynamics AX 2012 R3 Blog bot DAX Blogs 0 08.12.2017 10:51
dynamicsaxse: February release – Dynamics AX 2012 R3 Blog bot DAX Blogs 0 02.03.2017 01:11
dynamics-coe: Microsoft Dynamics AX 2012 Reporting Services – Integrated with SharePoint Farm Blog bot DAX Blogs 0 21.11.2014 13:11
emeadaxsupport: AX Content: Make Microsoft Dynamics AX 2012 yours! Blog bot DAX Blogs 0 01.10.2013 00:12
Часовой пояс GMT +3, время: 03:35.
