Старый 05.08.2023, 07:35   #1
How to select\unselect all records in a form grid
Источник: http://alexvoy.blogspot.com/2023/08/...ecords-in.html
While adding standard command button you can opt for SelectAll to mark all records in a form grid. However, there is no such a command for the opposite - unselect all records.
You can easily achieve it by using the following method and two usual button form controls.
[Form]public class mgcDeleteForm extends FormRun{ public void selectAll(boolean _select) { VendPaymFormat_DS.markAllLoadedRecords(_select); } [Control("Button")] class FormButtonControlSelectAll { public void clicked() { element.selectAll(true); super(); } } [Control("Button")] class FormButtonControlUnSelectAll { public void clicked() { element.selectAll(false); super(); } }}
dynamicsaxhints: How to update a caller form when a new record is created in a separate form in AX 2012 Blog bot DAX Blogs 0 31.08.2016 01:13
stoneridgesoftware: Creating a Default Lookup Form with Filter in Dynamics AX Blog bot DAX Blogs 0 29.07.2016 02:37
tlefor: Dynamics AX 2012: How Wide is my Grid Column? Blog bot DAX Blogs 0 28.10.2013 10:11
fatihdemirci: How to change grid row color in listpage form in Dynamics Ax 2012 Blog bot DAX Blogs 0 20.05.2013 18:11
CRM DE LA CREME! Some more useful javascripts for MS CRM Blog bot Dynamics CRM: Blogs 0 04.05.2010 11:05
Часовой пояс GMT +3, время: 11:46.
