Старый 12.12.2023, 15:11   #1
a33ik: AX 2012 Number sequence DataTypeName
Источник: http://daxonline.org/1933-ax-2012-nu...atypename.html
Use the following code to add DataTypeName to a Number sequence references export from AX 2012:
static void VKTest(Args _args){ #File IO iO; FilenameOpen filename = "c:\\_temp\\number seq references v2.csv"; FilenameOpen filenameWrite = "c:\\_temp\\number seq references v2 extended.csv"; Container record; Container recordWrite; int recordCounter = 0; int dataType; str dataTypeName = 'DATATYPENAME'; CommaTextIo fileWrite; FileIoPermission perm; ; iO = new CommaTextIo(filename,#IO_Read); if (!iO || iO.status() != IO_Status::Ok) { throw error("@SYS19358"); } perm = new FileIoPermission(filenameWrite, #io_write); perm.assert(); fileWrite = new CommaTextIo(filenameWrite, #io_write); if (!fileWrite || fileWrite.status() != IO_Status::Ok) { throw error("@SYS19358"); } while (iO.status() == IO_Status::Ok) { record = iO.read(); //To read file if (recordCounter) { dataType = conpeek(record, 9); dataTypeName = extendedTypeId2Name(dataType); } recordWrite = record + dataTypeName; fileWrite.writeExp(recordWrite); recordCounter++; } //info(strFmt("%1", extendedTypeId2Name(1295))); }
AX 2012 Read / Write CSV file
dynamicsaxse: November 2017 Release – Dynamics AX 2012 R3 Blog bot DAX Blogs 0 08.12.2017 10:51
emeadaxsupport: Number sequence XXXX has been exceeded Blog bot DAX Blogs 0 29.04.2014 20:11
rumicrosofterp: Dynamics AX на Convergence 2012 Blog bot Microsoft и системы Microsoft Dynamics 0 13.01.2012 11:11
Dynamics AX на Convergence 2012 Blog bot Microsoft и системы Microsoft Dynamics 0 13.01.2012 10:52
Часовой пояс GMT +3, время: 00:58.
