Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 25.10.2007, 16:52   #1
ist is offline
ist
Filter By Field
Hi,
Fist I'm apologize for my English.
I have a following situation:
I must change ItemId lookup into InventJournalTransfer form, becouse I must display ExtCodeValue from ExtCodeValueTable (if any) for the items.
I have created new form in AOT form node.In datasource node (on the form), I have added two tables: InventTable and ExtCodeValueTable. JoinSource on the ExtCodeValueTable is InventTable and JoinMode is OuterJoun becouse some items may has not external code.InventTable and ExtCodeValueTable has link - InventTable.RecId = ExtCodeValueTable.ExtCodeRelationRecId.The form have a grid control with some fields from standart lookup (InventTable), and one field from ExtCodeValueTable (ExtCodeValue which is external code).
The problem is:
I have to filter by ExtCodeValue.When I click "FilterBySelection" on contectMenu in field column, it's executed filter method on the fieldControl.In this method I do this:
public void filter(str _filterStr)
Query query InventTable_Q;
    if(
query.dataSourceTable(tableNum(ExtCodeValueTable)).joinMode() == JoinMode::OuterJoin)
query.dataSourceTable(tableNum(ExtCodeValueTable)).joinMode(JoinMode::InnerJoin);
InventTable_ds.executeQuery();
super(_filterStr);
the filter is removed from removeFilter method on the InventTable datasource that I have overrided.
public void removeFilter()
    Query query = InventTable_Q;
    if(query.dataSourceTable(tableNum(ExtCodeValueTable)).joinMode() == JoinMode::InnerJoin)
        query.dataSourceTable(tableNum(ExtCodeValueTable)).joinMode(JoinMode::OuterJoin);
    super();
To this all is ok , but when i filtering with "Find by Field" from context menu on the ExtCodeValue column, I want to change also JoinMode to InnerJoin.The problem is that I dont know which method is invoked for this comand. The Dasource(InventTable) method findValue() is not invoked although that in the help write exact this.
thank you in advance.
Старый 25.10.2007, 17:01   #2
EVGL is offline
EVGL
Banned
4,445 / 3001 (0) ++++++++++
.executeQuery() is called.
Старый 25.10.2007, 17:55   #3
ist is offline
ist
Ok but how I can distinctwish executeQuery() with and without filtering?
When "filter by field" is enabled i have to change JoinMode from OuterJoin to InnerJoin.
Старый 25.10.2007, 18:01   #4
EVGL is offline
EVGL
Banned
Сообщение от ist Посмотреть сообщение
Maybe you cannot.
Try to look if a range exists on your field.
Старый 25.10.2007, 18:57   #5
ist is offline
ist
Maybe you cannot.
When it is filtering with "Filter By Field" strange why executeQuery did not invoke.
public void executeQuery()
    QueryBuildRange qbr;
    Query query = this.query();
    qbr = this.query().dataSourceTable(tableNum(ExtCodeValueTable)).findRange(fieldNum(ExtCodeValueTable, ExtCodeValue));
    if(qbr)
    super();
The debuger does not stop on the breakpoint
Старый 25.10.2007, 18:57   #6
ist is offline
ist
Maybe you cannot.
    if(qbr)
    super();
Старый 26.10.2007, 15:41   #7
Russland is offline
Russland
Аватар для Russland
267 / 116 (4) +++++
1. Override filter() method on ExtCodeValue field (ExtCodeValueTable data source) like this:
public void filter(str _filterStr, NoYes _clearPrev)
    if(!_filterStr)
        _filterStr = InventTable::findRecId(ExtCodeValueTable.ExtCodeRelationRecId).ItemId;
    InventTable_ds.query().dataSourceTable(tableNum(ExtCodeValueTable)).joinMode(JoinMode::InnerJoin);
    super(_filterStr, _clearPrev);
2. Override removeFilter() method on InventTable data source:
    InventTable_ds.query().dataSourceTable(tableNum(ExtCodeValueTable)).joinMode(JoinMode::OuterJoin);
    super();
Hope it will solve your problem
В глухомани, в лесу Несмотря на красу Дни проводит Лиса Патрикевна. Я никак не пойму Отчего, почему Не пускают куму На деревню
Старый 30.10.2007, 17:49   #8
ist is offline
ist
All is Ok.
Сообщение от Russland Посмотреть сообщение
    if(!_filterStr)
    super();
All is OK.Thank'a a LOT.
axaptapedia: Filter-by-Grid Blog bot DAX Blogs 2 30.05.2012 13:39
axStart: Check if the table field is mapped. Blog bot DAX Blogs 0 07.03.2009 00:05
palleagermark: Set focus on a particular field on an EP page Blog bot DAX Blogs 0 27.11.2008 14:05
axStart: table & field ID conflicts Blog bot DAX Blogs 0 29.05.2008 17:05
Kashperuk Ivan: Hotkeys and Find vs Filter in Dynamics AX 2009 Blog bot DAX Blogs 2 11.03.2008 12:06
Часовой пояс GMT +3, время: 06:12.
