#1 |
axStart: Check if the table field is mapped.
Источник: http://axstart.spaces.live.com/Blog/...C0A0!482.entry
============== Let’s have a look at the next scenario: • I have added a new field on my table map. • This new field not used on al the tables that use this table map. • I use this mapped field inside my table method. If you don’t check it, you get an error about field ID is zero and you are not in the mood to check for all places where this method is use. And you don't want to change AX on all those places Solution: TreeNode::findNode(#TableMapsPath+'\\Map\\Mappings\\'+tableid2name(this.TableId)+'\\Field'); If the TreeNode exist the field is not mapped. Example: public static void initMapFromMap(AddressMap _toAddress, AddressMap _fromAddress) { #AOT _toAddress.Address = _fromAddress.Address; _toAddress.Street = _fromAddress.Street; _toAddress.ZipCode = _fromAddress.ZipCode; _toAddress.City = _fromAddress.City; _toAddress.County = _fromAddress.County; _toAddress.State = _fromAddress.State; _toAddress.CountryRegionId = _fromAddress.CountryRegionId; if(TreeNode::findNode(#TableMapsPath+'\\AddressMap\\Mappings\\'+tableid2name(_toAddress.TableId)+'\\Telex') && TreeNode::findNode(#TableMapsPath+'\\AddressMap\\Mappings\\'+tableid2name(_fromAddress.TableId)+'\\Telex')) _toAddress.Telex = _fromAddress.Telex; } ![]() ![]() Источник: http://axstart.spaces.live.com/Blog/...C0A0!482.entry
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
Опции просмотра | |
