Старый 10.03.2010, 01:05   #1
mscrmblog: Mini Preview Window for Contact Lookup Field
Источник: http://mscrmblog.net/2010/03/09/mini...-lookup-field/
Looks cool doesn’t it. well here goes nothing..
to achieve the above you will need the following (click read more link..)
// the following code is for the hover over lookup windowfunction OnCrmPageLoad(){ /* Reference the to Lookup, Provide the lookup (control) id. */ var PrvToLui = new LookupPreview("new_primarycontactid"); /* Add Account Preview Information , returns an account entity wrapper object */ var accountEntity = PrvToLui.AddEntity("account"); /* Add Account Preview Attributes, Provide lable and schema name for each attribute */ accountEntity.AddAttribute("Business Phone","address1_line1"); accountEntity.AddAttribute("Mobile Phone","address1_city"); accountEntity.AddAttribute("Fax","address1_stateorprovince"); accountEntity.AddAttribute("E-mail","address1_postalcode"); /* Add Related Entity (Primary Contact) Information AddLinked requires the entity name and lookup field schema name on the account. */ var contactEntity = accountEntity.AddLinked("contact","primarycontactid"); contactEntity.AddAttribute("Primary Contact","fullname"); contactEntity.AddAttribute("Contact Phone","telephone1"); /* ------------------------------------------------------------------ */ //Contact Entity Preview var contactEntity = PrvToLui.AddEntity("contact"); contactEntity.AddAttribute("Business Phone","telephone1"); contactEntity.AddAttribute("Mobile Phone","mobilephone"); contactEntity.AddAttribute("Fax","fax"); contactEntity.AddAttribute("E-mail","emailaddress1"); var accountEntity = contactEntity.AddLinked("account","parentcustomerid"); accountEntity.AddAttribute("Parent Company", "name"); accountEntity.AddAttribute("Parent Street","address1_line1"); accountEntity.AddAttribute("Parent Suburb","address1_line2"); accountEntity.AddAttribute("Parent State","address1_stateorprovince"); accountEntity.AddAttribute("Parent Postcode","address1_postalcode"); accountEntity.AddAttribute("Parent Website","websiteurl"); /* ------------------------------------------------------------------ */}function LookupPreview( lookupId ){ var Instance = this; Instance.Lookup = document.getElementById( lookupId ); if( isNullOrEmpty(Instance.Lookup) ) return; //Public Instance.Entities = []; Instance.AddEntity = function(entityName){ var Entity = new Object(); Entity.Name = entityName; Entity.AddAttribute = function( labelName , attrName ){ var Attributes = Instance.Entities[entityName].Attributes; var attribute = new Attribute(entityName , attrName , labelName , attrName); Attributes[Attributes.length] = attribute; DisplayAttributes[DisplayAttributes.length] = attribute; } Entity.Attributes = []; Entity.LinkedByName = []; Entity.LinkedByIndex = []; Entity.AddLinked = function( lnkEntityName , referencingAttribute ) { var LinkEntity = new Object(); LinkEntity.Name = lnkEntityName; LinkEntity.Attributes = []; LinkEntity.RefAttribute = referencingAttribute; LinkEntity.AddAttribute = function( labelName , attrName ) { var attribute = new Attribute(entityName , attrName , labelName , LinkEntity.RefAttribute + "." + attrName); LinkEntity.Attributes[LinkEntity.Attributes.length] = attribute; DisplayAttributes[DisplayAttributes.length] = attribute; } Entity.LinkedByIndex[Entity.LinkedByIndex.length] = Entity.LinkedByName[name] = LinkEntity; return LinkEntity; } Instance.Entities[entityName] = Entity; return Entity; } Instance.Show = function(dataElement) { var control = Instance.Lookup; var DataValue = control.DataValue; if( isNullOrEmpty(DataValue) ) return; if( isNullOrEmpty(Instance.Entities[DataValue[dataElement.Index].typename]) ) return; TooltipPopup = window.createPopup(); if( !dataElement.PreviewHTML ) { var ToolTipHTML = "Preview"; var xmlHttp = CreateXmlHttp(); var xml = ""; xml += GenerateAuthenticationHeader(); xml += ""; xml += ""; xml += ""; var fetchxml = ""; var DataVal = control.DataValue[dataElement.Index]; var entity = DataVal.typename; fetchxml += ""; var attributes = Instance.Entities[entity].Attributes; for( var i = 0 ; i < attributes.length ; i++ ) fetchxml += ""; fetchxml += ""; fetchxml += ""; fetchxml += ""; for( var i = 0 ; i < Instance.Entities[entity].LinkedByIndex.length ; i++ ) { var linked = Instance.Entities[entity].LinkedByIndex[i]; fetchxml += ""; for( var j = 0 ; j < linked.Attributes.length ; j++ ) fetchxml += ""; fetchxml += ""; } fetchxml += ""; fetchxml += ""; xml += _HtmlEncode(fetchxml); xml += ""; xml += ""; xml += ""; xml += ""; xmlHttp.open("POST", "/mscrmservices/2007/crmservice.asmx", false ); xmlHttp.setRequestHeader("Content-Type", "text/xml; charset=utf-8"); xmlHttp.setRequestHeader("SOAPAction", "http://schemas.microsoft.com/crm/2007/WebServices/Fetch"); xmlHttp.send(xml); var resultDoc = loadXmlDocument(xmlHttp.responseXML.text); var previewHtml = "
"; dataElement.Width = 0; //debugger for( var i = 0 , j = 1; i < DisplayAttributes.length ; i++ ) { var attribute = DisplayAttributes[i]; if( attribute.Entity != entity ) continue; var attrNode = resultDoc.selectSingleNode("//" + attribute.XPathName ); var attrValue = (attrNode)? attrNode.text:""; dataElement.Height = (j++) * 22; var maxLength = ( attrValue.length + attribute.Label.length ) * 9; if( dataElement.Width < maxLength ) dataElement.Width = maxLength; previewHtml += "" + attribute.Label + "" + attrValue + ""; } dataElement.Height += 20; ToolTipHTML += previewHtml; ToolTipHTML += ""; dataElement.PreviewHTML = ToolTipHTML; } TooltipPopup.document.body.innerHTML = dataElement.PreviewHTML; var Position = getControlPostion(); var Left = Position.X + 1; var Top = Position.Y + 5; TooltipPopup.show( Left , Top - dataElement.parentElement.scrollTop , dataElement.Width, dataElement.Height , null ); } Instance.Hide = function() { if( TooltipPopup ) TooltipPopup.hide(); } Instance.OnLookupChange = function() { var jump = 0; if( Instance.Lookup.DataValue != null ) { var DataElementsLen = Instance.Lookup.parentElement.previousSibling.childNodes[0].childNodes.length; var DataValuesLen = Instance.Lookup.DataValue.length; jump = (DataElementsLen == DataValuesLen)? 1:2; for( var i = 0 ; i < DataValuesLen*jump ; i+=jump ) { var DataValueElemet = Instance.Lookup.parentElement.previousSibling.childNodes[0].childNodes[i]; if( !isNullOrEmpty(DataValueElemet.onmouseover) ) continue; DataValueElemet.Preview = Instance; DataValueElemet.Index = i/jump; DataValueElemet.onmouseover = function(){ this.Preview.Show(this); } DataValueElemet.onmouseout = function(){ this.Preview.Hide(); } } } } //Private var TooltipPopup; var DisplayAttributes; function Init() { DisplayAttributes = []; Instance.Lookup.attachEvent( "onchange" , Instance.OnLookupChange ); Instance.OnLookupChange(); //First Time } function Attribute(entityName,attrName,attrLabel,attrXpathName) { this.Name = attrName; this.Entity = entityName; this.Label = attrLabel; this.XPathName = attrXpathName; } function getControlPostion() { control = event.srcElement; var Position = new Object(); var controlHeight = control.offsetHeight; var iY = 0, iX = 0; while( control != null ) { iY += control.offsetTop; iX += control.offsetLeft; control = control.offsetParent; } Position.X = iX + screenLeft; Position.Y = iY + screenTop + controlHeight; return Position; } function isNullOrEmpty( obj ){ return obj == null || typeof(obj) == "undefined" || obj == ""; } Init();}OnCrmPageLoad();OK, this is what needs to be edited if you need custom attributes listed in the preview window.
you may edit the following code block:
contactEntity.AddAttribute("Business Phone","telephone1"); contactEntity.AddAttribute("Mobile Phone","mobilephone"); contactEntity.AddAttribute("Fax","fax"); contactEntity.AddAttribute("E-mail","emailaddress1");“Business Phone” represents the label on the preview form
“telephone1″ is the attribute on the contact entity
I have uploaded a text file with all the code at: http://mscrmblog.net/downloads/previewWindow.txt
This code is pretty self explanatory.. however if you need some help, email me or post a comment
Microsoft Dynamics CRM Team Blog: Customizing the CRM Lookup Return Field Blog bot Dynamics CRM: Blogs 0 28.04.2009 06:11
Создание Lookup формы Maxim Gorbunov DAX: База знаний и проекты 9 26.06.2007 16:44
Lookup -> field braathe DAX: Программирование 3 01.03.2005 15:26
Lookup field axaLearner DAX: Программирование 4 26.10.2004 17:34
Часовой пояс GMT +3, время: 12:09.
